34 Users Online (33 Members):
Forums >> Revit Building >> Technical Support >> Stacked Wall Proplem
1 Posts No Rating |
I have made a stacked wall where the bottom half is wider then the top, when i try to attached it to the roof, the bottom half attaches and it deletes the top half. Can anyone help me?
27 Posts No Rating |
I've got exactly the same problem, did you have any luck finding a solution?
Make a new level. Have the bottom half start at one elevation and end at another, then have the upper wall start at the elevation the bottom half stops at and then attach THAT to the roof. It's great because if you want the bottom half to grow in height all you have to do is move the elevation level up (or down) and the wall behaves as it should. Well, it did for me; I'm using 2010 by the way.
stacked wall line visable on the wrong side? |
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls |
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue |
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems |
Tue, Oct 14, 2008 at 12:50:52 PM
Members: | 2019203 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
