43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> rotated curtain grids?
20 Posts No Rating |
Hi everyone! Does anyone know who to rotate a curtain grid? I have an entire system that needs to be at a 45 degree angle... Thanks! -Jen
I actually found it onmy own - for those who need the answer, go to an elevation view (you might not have to be in an elevation but I was having trouble in my axon views) and select the entire curtain wall. (make sure your gird lines are not pinned.) Select the "Configure Grid Layout" icon - looks like a torqued curtain grid. You'll see 2 sets of info - a dimension and degree for first direction, and a dimension and degree for the second. Type in the desired angles and you're good to go! Hope this helps someone other than me! -Jen
Revit sloped glazing & angled curtain grids problem |
Thu, Feb 25, 2016 at 11:33:26 PM
11
Random Diagonal Curtain Grids in a Curtain Wall |
Wed, Jul 6, 2011 at 6:57:03 AM
non parallel curtain wall grids |
Sat, Apr 28, 2007 at 12:54:05 AM
revealing hidden curtain grid |
Mon, Sep 8, 2008 at 3:55:02 PM
Way to create exterior facade on rotated curtain wall face ? |
Tue, Aug 2, 2016 at 6:17:10 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
