101 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> auditorium seating
Tue, Mar 6, 2007 at 11:10:46 AM | auditorium seating
brl1585
Does anyone know the process of using revits scheduling tools to calculate approximate seating by defining seating area with room separation lines?  I know revit has this capability, I have some text on this (see attached), but it is quite vague.  The text mentions shared parameters and calculated values but I dont know how to set these up to do what I want.  This would save a ton of time by being able to approximate seating based on area rather than having to place actual geometry and counting.  If the attachment is not clear enough to read, it shows using a schedule with columns:  Seating area, Area per Seat, and Proposed Seating which is automatically calculated from the previous two columns.  If anyone knows how to do this it would be a huge help.
Tue, Mar 6, 2007 at 11:50:19 AM | auditorium seating
robinballew
robinballew Avatar
3 Stars: 4 Votes
I looks like what you want is to be able to define an area and then devide it by some standard number like 4.5 and get a total. If so, set up a Room Schedule that lists the rooms or areas you want defined. Edit the schedule and click on Fields. In the new box click on Calculated Value and define a new value called Seats per Area(see image), make the Type, Area, and define the formula as Area/(what ever you want).
BallewDesigns.com
Tue, Mar 6, 2007 at 12:04:45 PM | auditorium seating
robinballew
robinballew Avatar
3 Stars: 4 Votes
Look at the Calculated Value in the Room Schedule. You can add a Parameter that will Divide the "Area" by whatever you want. See attached
BallewDesigns.com
Tue, Mar 6, 2007 at 12:05:46 PM | auditorium seating
brl1585
Thanks alot, thats what i needed
Tue, Mar 6, 2007 at 12:10:30 PM | auditorium seating
brl1585
If I want a field that is just constant...not affected by editing the room area, for instance, just saying that the area that one seat takes = 4.5sf.  what is the best way to do that
Wed, Mar 7, 2007 at 8:30:38 AM | auditorium seating
robinballew
robinballew Avatar
3 Stars: 4 Votes
I don't get that last question...
BallewDesigns.com
Wed, Mar 7, 2007 at 8:43:04 AM | auditorium seating
brl1585
Sorry, I just want a column labeled Area Per Seat that has a fixed number.  I figured it out though.  I just added a parameter.  Thanks for your help.
Auditorium Seating
Wed, Sep 8, 2010 at 7:07:57 AM
Documenting Existing Auditorium seating along a curve
Mon, Jan 18, 2016 at 3:05:13 PM
Auditorium Seating from CAD to Revit
Fri, Feb 19, 2010 at 1:25:30 PM
stadium style seating
Thu, Apr 30, 2009 at 9:36:59 AM
Retractable seating
Sat, Apr 30, 2016 at 9:18:14 AM
Page generation time: 0.2791
