49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> using schedule keys, shared parameters and calculated values in schematic design
Mon, Mar 5, 2007 at 3:29:18 PM | using schedule keys, shared parameters and calculated values in schematic design
brl1585
Is it possible to begin a design by imbeding data from a spreadsheet such as a room schedule and use that data to assist in laying out room sizes.  I have seen where it can calculate differences in desired room sizes and actual.  I know this process has something to do with schedule keys, shared parameters and claculated values, but i dont know how to set it up or use it efficiently.
Tue, Mar 6, 2007 at 11:35:58 AM | using schedule keys, shared parameters and calculated values in schematic design
brl1585
I realize the above thread may not be perfectly clear.  I have a little text that introduced me to the idea...but it does not tell me a process to set it up.  See the attached file to get a better understanding of what I am looking for.  The schedule to the side of the drawing might be too small to read.  It is a room schedule and the columns are as follows:
Area, Desired Area, Difference (SF), and Difference (%)
How can I set up this schedule so that these columns talk to eachother: e.g. Desired area - Area = Difference
Tue, Mar 6, 2007 at 12:00:02 PM | using schedule keys, shared parameters and calculated values in schematic design
robinballew
robinballew Avatar
3 Stars: 4 Votes
Calculated values in the schedule. Click on Fields and Calculated Values. It's easy from there.
BallewDesigns.com
Tue, Mar 6, 2007 at 1:31:07 PM | using schedule keys, shared parameters and calculated values in schematic design
brl1585
How do I add a field that I can insert my own values for?
e.g.
Desired Area: office1-150sf; office2-175sf; office3...
Tue, Mar 6, 2007 at 1:41:36 PM | using schedule keys, shared parameters and calculated values in schematic design
robinballew
robinballew Avatar
3 Stars: 4 Votes
Add a parameter call Desired Area, then add a calculated Value the formula is Area-Desired Area. See Attached
BallewDesigns.com
Calculated Values in Room Tags
Wed, Mar 30, 2011 at 4:08:03 PM
Schedule Calculated Values
Fri, Mar 27, 2015 at 12:05:13 PM
Calculated Values
Mon, Mar 3, 2008 at 11:01:17 AM
Schedule Calculating Field
Tue, Mar 10, 2009 at 5:25:50 AM
Calculated Values
Mon, Mar 20, 2006 at 12:58:54 AM
Page generation time: 4.9234
