Forums >> Revit Building >> Technical Support >> Angled Curtain Walls - Not Sloping Glazing
11 Posts No Rating |
Hi all, I am struggling on this issue... i have tried to create a mass with profile i want, but the curtain wall won't what attach to the face >< (Refer picture attached) Is there a better way? Or will it just not work??? Dale TSArchitects Melbourne, Australia
------------------------------------ Dale Melbourne VIC, Australia |
OK, OK... I may have rushed this post in a panic.... just after i made it i tried the curtain system by face command... and all is good now. Thank you (in advance) to anyone who would have replied. Cheers. Dale
Further to this problem now that i have the whole angled wall thing working, the system panels do not seem to align to the grid??? View the attached .jpg to see what i mean. My next problem with this that when i insert a 150x50 mullion they don't align at the corners... this is quite confusing and frustrating - is there as simple solution - or is it simply too complex for revit to handle? Cheers, Dale
Edited on: Sun, Mar 4, 2007 at 5:31:51 PM
25 Posts No Rating |
hi i managed to create slanted walls with the massin tool but i wanted to create a slanted curtain wall and i tried to apply the curtain wall by face it wont work on the mass or any other wwall, please advice as i am still new to revit architecture and its quite important for me to include this element into my project very urgent.... cheers muf
Hi, see this: http://screencast.com/t/drCAZO85
hi there from the video i can see after editin the system u can go dirtectly and select the walls u want to chnage but with me after editing it just doesnt let me select any walls and that small box which appears doesnt select any face what should i do i am really stuck..... muf
What?? that don't make sense, can you provide some video to check what/how are you doing that????
Raking curtain walls, adding tags to Shop Front glazing |
Tue, Mar 7, 2006 at 9:35:59 PM
Revit sloped glazing & angled curtain grids problem |
Thu, Feb 25, 2016 at 11:33:27 PM
11
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:48 PM
Sloping & angled walls |
Fri, Oct 8, 2004 at 12:37:28 AM
Glazing in curtain walls |
Thu, Dec 10, 2015 at 7:38:16 AM
Members: | 2098083 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
