112 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> The family is not of the correct category
Fri, Mar 2, 2007 at 3:19:00 PM | The family is not of the correct category
Tinner
I'm trying to make some custom structural steel framing, specifically a beam stub on the face of a column.  Each time I try and load a profile, I get the error about the family not being the correct type.  The family is a column family to start with, but I can't load from the column family or the beam family either.  I'm actually unable to load any of the families at all.
I also tried one of the tutorial lessons following the exact procedure where they make a curved beam and get the exact same error, after the sweep it won't let me load anything.
Any ideas?
Sat, Mar 3, 2007 at 10:36:02 AM | The family is not of the correct category
robinballew
robinballew Avatar
3 Stars: 4 Votes
Post the family so we can check it out.
BallewDesigns.com
Mon, Mar 5, 2007 at 9:06:02 AM | The family is not of the correct category
Tinner
Here is the beam and column family files we're using.
Another fellow in our office has the trial version and he has been able to follow the tutorial and load any type of profile when I cannot.
Mon, Mar 5, 2007 at 10:01:16 AM | The family is not of the correct category
robinballew
robinballew Avatar
3 Stars: 4 Votes
Works fine. You might try reloading Revit...
BallewDesigns.com
Wed, Jul 29, 2009 at 8:35:24 PM | The family is not of the correct category
gfdyck
  I have almost the same problem. Made a fully parameteric tappered beam with an adjustable hunch but can  not load it into any project. Could anybody tell me what is wrong with it
Sat, Feb 19, 2011 at 5:50:00 PM | The family is not of the correct category
TantrumXL
TantrumXL Avatar
Yeah I get the same thing, I can't load any Beam or Structure families into my current 2d sketch. It comes up with "The family is not of the correct category". Help out?
If cocky means i'm confident,
There's no way i'm stopping it.
The family is not the correct category
Tue, Sep 12, 2006 at 8:39:42 PM
Family is not of the correct category
Thu, Apr 13, 2006 at 1:06:26 PM
family is not of the correct category?
Tue, Aug 23, 2005 at 10:29:46 AM
Revit 2012 The family is not of the correct category problem
Mon, Mar 19, 2012 at 8:12:04 AM
Baluster category/sub category
Tue, Nov 19, 2013 at 9:43:57 PM
Page generation time: 3.7522
