78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> Floor patterns being assigned to one floor type changes others
27 Posts No Rating |
We are trying to create a variety of floor types with different floor patterns to show floor finishes. We are duplicating and renaming a floor (system) family and assigning a fill pattern. When we duplicate and rename the system family to assign a different pattern, both the new family and the old one display the same fill pattern (the first floor type still lists the original pattern in the properties, but displays the other). So, we can't set up, for example, a 4" tile pattern and a 12" tile pattern. We must be doing something obviously wrong here, but we can't figure it out.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Your surface patterns are assigned to a material. If you are using the same material then you will get the same surface pattern.
how do you get different colors for same type of floor? |
Fri, Dec 10, 2010 at 5:40:02 AM
Floor Finishes not showing up in Revit 2013 |
Thu, Dec 25, 2014 at 5:52:36 AM
Floor patterns diff directions same pattern. |
Sun, Sep 27, 2009 at 4:57:09 PM
floor coverings |
Tue, Feb 15, 2011 at 8:25:21 AM
Creating patterns on floor with design options |
Tue, Apr 21, 2009 at 11:52:27 AM
Members: | 2016941 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
