61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Rev Clouds
27 Posts No Rating |
Hi, Is it possible to edit the apperance of the revision clouds, ie colour and arc length? many thanks in advance.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Color, yes. Arc length, only by how far you drag the line when you're making the Revision Cloud. To change the color, go to Settings >> Object Styles then under Annotation Object scroll down to Revision Clouds. Change the color, line weight etc. there. HTH!
brillant, thanks very much.
9 Posts No Rating |
Revit revision clouds suck! Have you figured out any way to change their appearance? I know how to change the color, but the arc lengths are what I'm disgusted with.
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
RAC 2010 - Revision Block Disappears on Rev. 2 |
Thu, Jul 8, 2010 at 11:16:36 AM
Creating Revision Clouds |
Fri, Nov 13, 2009 at 6:29:50 AM
Sheet Issues/Revisions - Previous Revision Clouds Halftone |
Wed, Aug 22, 2012 at 11:03:14 AM
revit 8.1 revision tables |
Sat, Oct 29, 2005 at 10:36:13 PM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
