64 Users Online (63 Members):
Forums >> Revit Building >> Technical Support >> Filtering out wall sweeps
6 Posts No Rating |
I have an elevation that shows a trash enclosure right smack in front of a door. I need the door to read through so I have filtered out the walls and gates that we have modeled in. The problem lies within trying to filter out the wall sweep I have used to create the cap of the wall. It is now time to send the project out to bid and I can't seem to get rid of that pesky sweep in elevation. Has anyone had experience with this??
Have you tried putting all of the items you don't want to show in a different phase?
Wall sweeps are a subcategory of walls in the Visibility/Graphics overrides, so you can turn them off in that particular view.
6 Posts No Rating |
I have several different sweeps on the building and need to keep them all on accept one. I've tried turning off the subcategory but it hides all sweep types. What I ended up finding to work was to change the subcategory to common lines and turn those off. I'm not exactly sure of a reason not to do this but I am certain there is one. The rest of the model and set od drawings did not seem to be effected.
Angling Wall Sweeps |
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps |
Wed, Feb 29, 2012 at 9:39:46 AM
Schedules - filtering by view or duplicate? |
Mon, Jul 28, 2014 at 8:24:36 AM
Wall sweeps line weight |
Wed, Apr 30, 2008 at 10:59:05 AM
Members: | 2017094 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
