Forums >> Revit Building >> Technical Support >> Parameter Formula
25 Posts No Rating |
PARAMETER FORMULA I am trying to work on a parameter formula to allow me to correctly flex a component. See attached image. Here is what I need the parameter formula to do: Length<=4' THEN 2 Length>4' upto and including 8' THEN 3 Length>8' but less than 12' THEN 4 Length=>12' but less than 16' THEN 5 Length=>16' THEN 6 That is it....let me know if you guys have any ideas in mind. Thanks, Recit
You can follow these guidelines for some more ideas. • Use conditionals in the definition of the parameter whose value is conditional. • In the Formula column next to the appropriate parameter, type the formula for the parameter. Noticethat the formula begins with an equal sign (=). • IF based on one test statement: =IF (Test Condition, Result if true, Result if false)IF ( Length < 35' , 2'-6", 3'-0" ) • IF based on more than one test: =IF (AND/OR (Test1, Test2) Result if true, Result if false)IF ( AND (x = 1 , y = 2), 8 , 3 )IF ( OR ( A = 1 , B = 3 ) , 8 , 3 ) • IF based on a negative test: =IF ( NOT (Test Condition), Result if true, Result if false)IF ( NOT ( A > B ) , 8 , 3 ) • Simple result if True, another IF if false: =IF (Test Condition, Result if true, IF (Test Condition, Result iftrue, Result if false ))IF ( Length < 35' , 2' 6" , IF ( Length < 45' , 3' , IF ( Length < 55' , 5' , 8' ) ) ) • Set one YES/NO parameter to the opposite of another: =NOT Y/N Parameter The question though is a complex conditional formula the best solution? Depending on what you are making can the array be driven by a type catalog? Can you do a first/last array and evlauate spacing via a formula that is simpler? Having a multi-nested conditional formula can lead to performace problems within the family. Of course that may not be a problem if you only have a couple of occurances within the project. If you have hundreds or thousands of them, then it is a different story. Without knowing more details it is hard to say what is the best option.
Edited on: Mon, Feb 26, 2007 at 5:38:09 PM
Tom www.reviteer.com http://twitter.com/Reviteer |
Recit, Take a look at the metalStud family I attached to my post here and see if the parameters in there help any. I use some parameters to control visibility and when/how an array functions based on the length of the family (it's line based so adapt as necessary). Let me know if you have any questions about it.
14 Posts No Rating |
Try this... If (Length < 3'11 63/64", 2, (If (and (Length >4' 0",Length < 8'0 1/64" , 3, (If (and (Length >8' 0",Length < 12'0" , 4, (If (and (Length >11' 11 63/64",Length < 16'0" , 5, (If (Length < 16' 0 1/64", 6, 0))))))))) Length must be a Length Parameter, and the Object parameter to be an Integer. Less than / greater than or equal to (<=, >=) don't work, so you need to make determinations on tolerances. I used 1/64th in this case. You also need to have a "Catch all" which is the final Parameter, for any open loop, or instance not covered. It acts as a check. I used Zero (0). I hope this helps...
You know, shortcut smileys shouldn't be active on a site that discusses LISP........ Everywhere you see a smiley in my previous post, assume a close parenthesis.....
THANKS GUYS FOR YOUR HELP. I CAN HANDLE EASY FORMULAS, BUT THE COMPLICATED ONES STILL BEAT ME DOWN! I'LL LET YOU KNOW IF IT WORKS.
Guys, after all your suggestions, here is the winning formula: if(Length = 16', 5, if(Length > 16', 6, if(Length = 12', 4, if(Length > 12', 5, if(Length = 8', 3, if(Length > 8', 4, if(Length > 4', 3, 2))))))) I learned that it makes a difference the sequence of numbers. That is to say that in the above formula begining from the bigger number and ending with a smaller number allows me to end it nicely. the numbering sequence is critical in the formula's behavior. In this case a decreasing sequence works much better than an increasing manner because it closes nicely with the last TRUE,FALSE)
I have found that the best way to stay organized with nested LISP Statements is to write each requirement on a line of excel and add XXXX under false, and then start at the bottom and enter the line into the previous line's false requirements... Like this>>> If (Length <= 4' 0", 2, xxxx) If (and (Length >4' 0",Length < 8'0" , 3, xxxx)If (and (Length >8' 0",Length < 12'0" , 4, xxxx)If (and (Length >12' 0",Length < 16'0" , 5, xxxx)If (Length <= 16' 0", 6, 0)
Turns into:
If (Length < 3'11 63/64", 2, (If (and (Length >4' 0",Length < 8'0 1/64" , 3, (If (and (Length >8' 0",Length < 12'0" , 4, (If (and (Length >11' 11 63/64",Length < 16'0" , 5, (If (Length < 16' 0 1/64", 6, 0))))))))) (If (and (Length >4' 0",Length < 8'0 1/64" , 3, (If (and (Length >8' 0",Length < 12'0" , 4, (If (and (Length >11' 11 63/64",Length < 16'0" , 5, (If (Length < 16' 0 1/64", 6, 0))))))))(If (and (Length >8' 0",Length < 12'0" , 4, (If (and (Length >11' 11 63/64",Length < 16'0" , 5, (If (Length < 16' 0 1/64", 6, 0))))))(If (and (Length >11' 11 63/64",Length < 16'0" , 5, (If (Length < 16' 0 1/64", 6, 0))))(If (Length < 16' 0 1/64", 6, 0))
One family parameter has formula one has none |
Wed, Jun 25, 2014 at 1:05:55 PM
Parameter Formula |
Fri, Mar 5, 2010 at 12:09:10 PM
Formula - IF statement |
Wed, Oct 25, 2006 at 6:54:25 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:25 PM
Parameter names with dashes - problem with formula |
Tue, Aug 31, 2010 at 10:28:40 AM
Members: | 2104459 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
