66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing colors of families
Sat, Feb 24, 2007 at 9:42:10 PM | Changing colors of families
ndiddy641
So here is the scoop....
I made an island family with a sink, range, and eating area. And of course I want to change the colors from the ugly flat grey. When I select the thing I want to change the color of and go to its properies and then to its material and select what I want, in this case it is the extruded object I used to fill inbetween my cabinets that I want to be cherry. Once I do that I go to the counter to make it granite, and it says it is cherry also. Everything turned cherry. And once I change one they all change to that one color. I dont get it....
Mon, Feb 26, 2007 at 6:23:49 PM | Changing colors of families
archdan
3.5 Stars: 2 Votes
If you joined teh geometry together, which it sounds like you did, then everything which is joined will have the same material (and many other properties) applied to all of the geometries.  Unjoin the geometries and start to apply materials again.
Mon, Feb 26, 2007 at 6:50:39 PM | Changing colors of families
rkitect
rkitect Avatar
4 Stars: 29 Votes
Or try the paint bucket tool to apply a material to the faces of the geometry.  I have not tried this but it may be worth a try.  Let us know if that works.
Mon, Feb 26, 2007 at 8:37:37 PM | Changing colors of families
Sumex
Sumex Avatar
I would unjoin and start from there.  I would create a material parameter for the objects that have similar materials, such as cabinet frames, fillers and doors.  That way, if you decide to change the finish of the cabinet system, it all changes in group.  It's much cleaner than joining geometry.  In addition, it can apply to the balance of the cabinets, and if you make it into a Shared Parmeter, it can be used in the Finish Schedule and/or Casework Schedule...
Changing colors of downloads
Wed, Jun 9, 2010 at 12:54:58 PM
Painting families so that colors are only visible in 3D view
Wed, Jan 9, 2013 at 7:56:17 AM
Similar wall types with different finish colors...
Thu, Apr 17, 2014 at 1:00:57 PM
changing object fill colors
Sun, Oct 11, 2009 at 9:28:18 AM
Windows showing up gray in consistent colors view.
Tue, Apr 26, 2016 at 11:25:23 AM
13
Page generation time: 0.6836
