84 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> linked Structural file visibility
Sat, Feb 24, 2007 at 2:31:51 PM | linked Structural file visibility
zmiles
I am having trouble with linking my structural consultants file (revit structures) into my file (revit building). When i linked it in i was only seeing 1 column when there should be over 100. I figured out that the coloumn i was seeing was in a different workset so i open the struc. file and moved everything to that workset and then i could see everything. has anybody else had this problem?
linked file visibility
Fri, Aug 23, 2013 at 8:05:12 AM
Linked File Visibility Management
Thu, Jan 3, 2008 at 6:11:31 AM
visibility of reinforcing from linked structural model in architectural sections
Thu, May 29, 2008 at 3:44:38 PM
Column / Wall Visibility between linked files
Mon, Apr 26, 2010 at 5:55:26 PM
Joining Beams and Floors - Beams in a Structural Linked File
Fri, Jun 22, 2018 at 10:07:05 AM
Page generation time: 2.4889
