117 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Texture Map Problems
Thu, Feb 22, 2007 at 2:04:00 PM | Texture Map Problems
Solopk
I am having an issue with texture maps behaving correctly at levels.  On my exterior elevations and perspectives, there seems to be a void in the texture at the level lines.  This leaves a strange condition when trying to convey an accurate brick pattern.  See attached image between first and second floor line.  Any thoughts on how to correct this?  Thanks
Thu, Feb 22, 2007 at 7:34:21 PM | Texture Map Problems
framerman
4 Stars: 13 Votes
it looks like you pattern is missing the horizontal grout line there which would lead me to believe that the hatch pattern isn't aligned properly. you can select your hatch lines by tabbing through if you've never done it before.
Sun, Feb 25, 2007 at 7:56:32 PM | Texture Map Problems
Rookwood
Common problem when stacking walls (constraining from level to level) or editing wall profiles. One reason to constrain your exterior walls from top of foundation to roof level.
Try this and I believe you will see this problem dissapear.
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:55 PM
Revit to 3D Max Texture map offset.
Thu, Oct 16, 2008 at 3:25:21 PM
Texture Map Gets Messed up after cut. (revit 2013)
Mon, Jul 1, 2013 at 9:10:11 AM
metal building question
Fri, Dec 20, 2013 at 8:39:29 PM
Help... Applying Rendering Texture to Sloping Wall
Mon, Dec 8, 2008 at 5:47:55 AM
Page generation time: 1.1601
