51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Bulkheads
Tue, Dec 7, 2004 at 10:17:09 AM | Bulkheads
Kirk
How do you wrap the gyp bd at the edge of a bulkhead? If you extend the wall down to the edge of the bulkhead how do you wrap the gyp? If the ceiling is at your finish height at your bulkhead, then the edge of the ceiling does not show gyp bd. For walls it says that wrapping only shows in plan view. What about showing in section or rendering?
Tue, Dec 8, 2009 at 12:41:02 PM | Bulkheads
pgrimmi
has anyone ever encountered this problem before? if so, how did you handle it? thanks for your time
Tue, Dec 8, 2009 at 3:32:04 PM | Bulkheads
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Overlap the ceiling and wall so they meet perfectly at the corner. Then join geometry between them.  If their layer priorites are setup correctly it will clean up correctly.
HTH.
Regards,
Chris.
Tue, Dec 8, 2009 at 3:55:34 PM | Bulkheads
pgrimmi
I'm sorry I should have read this more closely. the ceiling is at a different height from the bottom of the bulkhead, and I want the gyp board to wrap around the bottom of the bulkhead. maybe I just need to draw it with detail line.
Tue, Dec 8, 2009 at 6:01:47 PM | Bulkheads
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, infill this section with a wall type to match the ceiling make up.
Regards,
Chris.
Bulkheads and Tags
Fri, May 18, 2007 at 9:26:09 AM
Bulkhead
Mon, May 14, 2007 at 1:33:58 PM
Stepped Ceiling
Wed, Dec 3, 2008 at 6:46:48 PM
Bulkhead
Mon, Jun 18, 2012 at 6:38:45 AM
view range in RCP
Wed, Apr 28, 2004 at 1:53:29 PM
Page generation time: 0.3834
