Forums >> Revit Building >> Technical Support >> How change levels in a walkthrough? (walking from 1st to 2nd story)
9 Posts No Rating |
I cant seem to find any info in the tutorials about changing levels during a walkthrough. How is this done?
to create a single walkthrough going to different levels, you can enter height of the camera while creating the walkthrough. when u r creating the camera path, on the top options bar u can fill in the height. i don think this option is available once u've placed the camera, u can only specify the height before putting the cam in.
You can adjust the camera after establishing the path. I did a "drive thru" in a parking garage that included going up a ramp. It might be interesting to go up some stairs or even an elevator.
what i do is next to the camera height box, thers a box that says level and you can change what level the cameras on but not the view.
----------------------------------- My Futurama Fan Fiction 'Hammer087' - http://futurama-madhouse.com.ar/fanfic/indexh.shtml#hammer087 |
Once you have created your walk through path, you can enter the walk through & add key frames. Toggle to the key frames where you want to adjust your view angle. Use F8 & adjust to your pleasure. The walk through will interpolate between the key frames.
Tnx WWHub just what i needed, F8 in walkthrough view ftw
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
How to model floor joists correctly in 2 story residential |
Sat, Nov 28, 2009 at 8:35:10 AM
Stairs |
Mon, Aug 10, 2009 at 3:13:08 PM
list attic window as 2nd floor window in schedule |
Wed, Jan 31, 2018 at 11:02:16 AM
Story and Non-story levels? |
Thu, Dec 11, 2008 at 2:09:58 PM
Walkthrough - 3D orbit/change levels |
Fri, Sep 19, 2008 at 6:04:57 AM
Members: | 2101693 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
