72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Stair Stringer Offset
30 Posts No Rating |
I created this stair, and for some reason, one of the stringers (see image: the back one on the longer/lower run) has offset itself from the stair and other stringers. The difference can be seen where the stringers end on the low side of the stair. I thought this was a fluke and remade the stair, but still had the same problem. Any idea why the stringer is doing this? Thanks a lot!
I'm assuming that's one run of stairs. If you're looking for a way to correct it, I'd just make 2 stairs there instead of one. I haven't the slightest why that's doing that. Maybe it might be the tight turnaround from your landing. It is strange.
Yea, I guess that will be the easiest way to deal with it. Thanks a lot!
42 Posts No Rating |
I see the landing has smth like stringer, a horizontal one.is it a seporate "mini" staircale with one big tread as a landing?or the whole thing is one stair with the landing?
13 Posts No Rating |
I am having the same problem with several of my stairs. wtf. I dont want to redo all the stairs as single runs that doesnt make an sense. Revit 2010 + update 1.
Move your runs apart. There needs to be a very short landing line between the teo runs.
Stringer in Stair by Run: Problem with offset |
Tue, May 6, 2014 at 7:44:18 PM
Stair stringer offset (2015) |
Mon, Sep 14, 2015 at 9:19:19 AM
Stair Stringer Question |
Fri, Jul 28, 2017 at 4:01:08 PM
Monolithic Stair with Stringer |
Wed, Aug 5, 2009 at 10:43:24 AM
stair stringer control question |
Tue, Oct 2, 2007 at 9:56:28 PM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
