108 Users Online (107 Members):
Forums >> Community >> The Studio >> Rotating a 4x4x1/4 angle
6 Posts No Rating |
How do you rotate a structural angle 4x4x1/4.
I can flip the face but I can not rotate the angle.
for instance
this
to this
Thanks lol
11 Posts No Rating |
the easiest way that I think there is, is to mirror it along one of it's sides and rotating it.
6 Posts No Rating |
The mirror command does not work if you try and mirror a structural angle from one of its sides.
The only way that I have found is by creating a structural family that has the angle rotated the correct way that I need in the drawing. (label the angle LLV or LLH)
When you place a structural object, it is associated to a work plane, typically a level. In section if you draw a reference plane at the angle you with the structural angle to be at, and set this as the work plane then draw in the structural component.
This should give you what you need. Unfortunately as a structural component the structural capabilities are associated to the workplane and as such cannot be rotated in a conventional manner.
6 Posts No Rating |
very frustrating, but i too have had to create another family with the angle pointing the other direction.
Resolved in 2016 or higher (possibly earlier). There is a cross-section rotate in the properties under constraints. Hope this helps.
Helped me, thank you Jesus! ![Smile](/images/smiles/smile.gif)
Rotating Items on X-axis |
Wed, May 25, 2011 at 12:56:39 PM
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
angled railing (not ramp or stair angle) |
Fri, Jan 20, 2017 at 12:27:41 PM
Rotating Objects in Elevation/Section |
Tue, Jan 27, 2009 at 8:17:15 AM
Getting angle parameter for a plywood fill region detail component to work SMART |
Wed, Jan 15, 2014 at 7:27:39 AM
Members: | 2017021 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
