66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Ceilings sloped in two directions?
Thu, Feb 15, 2007 at 10:38:58 AM | Ceilings sloped in two directions?
smurphy
I've been trying to model a ceiling that slopes in two directions. When I try the slope arrow in a diagonal line, Revit picks one of the two orthagonal directions to slope the ceiling but not both at once. Any suggestions?
Thu, Feb 15, 2007 at 5:38:42 PM | Ceilings sloped in two directions?
framerman
4 Stars: 13 Votes
If I'm understanding you correctly, you would need 2 slope arrows to accomplish what you are talking about. I would run the slope arrows perpendicular instead of diagonally. A slope arrow shows where the plane surface direction is going and you tell it to slope "x"
if you are still having trouble, try posting a screenshot  of what you are trying to do if you can.
Thu, Feb 15, 2007 at 6:40:05 PM | Ceilings sloped in two directions?
smurphy
revit doesn't allow me to create a second slope arrow after placing the first one. i think i figured it out, though. if you use a work plane for the first slope, then apply a slope arrow for the second slope, you get a ceiling sloped in two directions.
Thu, Feb 15, 2007 at 7:27:32 PM | Ceilings sloped in two directions?
puzzle
4 Stars: 10 Votes
you could make an in-place ceiling using a extrusion blend.
Macca
Sunshine Coast
QLD Australia
Thu, Feb 15, 2007 at 7:56:58 PM | Ceilings sloped in two directions?
framerman
4 Stars: 13 Votes
ah, sorry, you're right. only one slope arrow on ceilings. you could make 2 separate ceilings or use the roof tool instead to get your 2 slope arrows.
puzzles advice is good too.
Thu, Nov 11, 2010 at 11:02:31 AM | Ceilings sloped in two directions?
JLT94
Hi smurphy, I am having trouble creating a sloping floor in 2 directions. I sloped my first plane, then set it as my working plan. Then I tried to add another slope arrow when I tried to edit the boundary of the same plane and I couldn't. How did you go about this again? Thanks, jlt
Thu, Nov 11, 2010 at 12:07:27 PM | Ceilings sloped in two directions?
You say you want a floor that slopes in the x and y directions?....  Well that is called an arrow along the hypoteneuse.   Just define it as elevation of head & tail instead of slope dimension.  Draw the arrow from corner to corner.
Edited on: Thu, Nov 11, 2010 at 12:07:57 PM
Sloped Ceilings
Thu, Jan 23, 2014 at 4:54:41 PM
14
SLOPED FLAT ROOF
Sat, May 9, 2009 at 9:09:39 AM
Skylight with slopes in 2 directions
Fri, Jun 7, 2019 at 10:54:50 AM
sloped ceilings?
Wed, Nov 10, 2010 at 12:37:48 PM
Slanted wall in section & sloped ceilings
Wed, Feb 18, 2009 at 2:10:45 PM
Page generation time: 0.5466
