131 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Schedule Count as Percent of Grand
Thu, Feb 15, 2007 at 7:52:55 AM | Schedule Count as Percent of Grand
hippy
This seems an easy concept but when I enter the formula I get an error count cannot be used in formulas. I need to show  that "room name count" / "grand total count" as a percentive. Someone has to have a work-around.
Thanks
Thu, Feb 15, 2007 at 10:22:34 AM | Schedule Count as Percent of Grand
TomDorner
4.5 Stars: 25 Votes
The built-in field of count cannot be used in a percentage calculation as the result would be meaningless which is why they don't allow it.  In order to give meaning to a room count one needs to group the database report [Revit schedule] on a meaningful field such as 'department' and create your own field called room count which is an integer and calculate out a percentage of that when grouped by department.
Alternatively, you can get a built-in room count if you sort/group by department, room type, name etc.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Dec 20, 2011 at 8:03:59 PM | Schedule Count as Percent of Grand
lpnoble
Sorry but I have a brain freeze, I am trying to accomplish this very thing and this explanation hasn’t sunk into to my thick skull!
I have different types of rooms
I have the count of each room type in the schedule
I have the total rooms at the bottom of the schedule (calculate totals switched on)
How do I get the percent of the room type to the grand total?
Thu, Dec 22, 2011 at 10:33:18 AM | Schedule Count as Percent of Grand
lpnoble
Well I did it!
This helped
http://forums.augi.com/showthread.php?t=50808&highlight=schedule+percentage+total
ROOM COUNT SCHEDULE
Tue, Aug 22, 2006 at 2:45:50 PM
Area schedule question: "Grand total" in formulas...
Thu, Nov 26, 2009 at 5:54:30 AM
Schedule Count Parameter
Wed, Sep 2, 2009 at 11:02:11 AM
Grand total text
Wed, Oct 21, 2009 at 11:14:59 AM
Schedules
Thu, Oct 27, 2005 at 3:06:05 PM
Page generation time: 1.2783
