94 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevation Split
Wed, Feb 14, 2007 at 7:33:05 PM | Elevation Split
grayd
Is there a way to split an elevation line similarly to splitting a seciton line?  I would just use a section, but I'd like to have it appear as an elevation tag as opposed to a section line.  Thanks.
Wed, Feb 14, 2007 at 9:26:42 PM | Elevation Split
rkarch
1 Stars: 1 Votes
many times I would have liked this grayd. Particularly when the contours obscure a part of the elevation a fair way from the 'elevation line'.....as far as I know it is not possible. Maybe Revit 10 (with simple canted walls!!)
Wed, Feb 14, 2007 at 9:33:22 PM | Elevation Split
rkarch
1 Stars: 1 Votes
I noticed this from Mr Spot in my search on this subject:
 "Easy. Turn on the crop region in the elevation. Select the crop region then hit one of the split lines to break the elevation into two parts. (4 quiggly lines around the border of the crop region.) Then adjust each crop to the area you want to see. Then select one crop region and you'll notice there is now an arrow in the centre. Drag this to drag each section closer together... HTH."
Thu, Feb 15, 2007 at 11:00:27 AM | Elevation Split
grayd
Ah, thanks rkarch.  I guess I should have been more clear in my original post.  I want to have a jogged elevation plane, changing the plane of reference within the elevation.  I'm pretty sure this is impossible and that I should just use a Section instead.
Thu, Feb 15, 2007 at 8:44:39 PM | Elevation Split
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To confirm, this is currently possible as of Revit 9.1.
Regards,
Chris.
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:35 PM
Level Split
Wed, Feb 1, 2012 at 4:04:32 PM
elevation split
Tue, Sep 23, 2014 at 8:17:18 PM
split segment on interior elevation view callout?
Tue, Sep 13, 2011 at 3:32:41 PM
Splits
Sun, Jan 30, 2005 at 9:30:04 PM
Page generation time: 1.8189
