60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Symbolic Lines Variation in Family
Wed, Feb 14, 2007 at 1:34:49 PM | Symbolic Lines Variation in Family
DCHNZ
Can anyone advise how I can vary the symbolic lines within a family.
The family is a filing cabinet which varies in the number of drawers 2- 3- 4 etc. But retains the same look in plan view. Depending on the quantity of drawers in that family type I to place a symbol to reflect this . Say 2 lines for 2 drawers, 3 lines for 3 and so on. Can symbolic lines be associated & displayed with a particular family type ? or is this one for the wish list???
Thanks
Wed, Feb 14, 2007 at 5:45:28 PM | Symbolic Lines Variation in Family
archdan
3.5 Stars: 2 Votes
Yes this can be done using a parameter linked to the visibility of the lines. Keep in mind thought that you may have to create new parameter for each drawer/door configuration you add.
Edited on: Wed, Feb 14, 2007 at 5:46:30 PM
Wed, Feb 14, 2007 at 6:15:48 PM | Symbolic Lines Variation in Family
DCHNZ
Thanks Dan, but could you elaborate on this.
Thu, Feb 15, 2007 at 1:33:22 PM | Symbolic Lines Variation in Family
archdan
3.5 Stars: 2 Votes
Start by drawing in the symbolic lines for the 2 drawer option, then associate them with a vibility parameter [select the lines>go to properties>then click the small grey box at the end of the "visible" line [after the check box] > new parameter window will open> create a parameter for 2 drawers and apply the new parameter].  Repeat these same steps for options for 3 drawers and 4 drawers.
Now these parameters can be controlled just like any other parameter [either through the Family Types dialouge in the family editor OR through the properties window of the family when it is loaded into a project].
 If the options will build on each other, i.e. the 3 drawer option splits the lower drawer of the 2 drawer option, then you would only need to draw the 3rd drawer line and associate the 3 drawer option with that [just make sure to keep the 2 drawer parameter checked].
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:18 PM
Symbolic lines in elevation
Thu, Jan 10, 2008 at 7:12:54 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:42 PM
Windows above the Cutplane and Symbolic Lines (Revit2010)
Wed, Jul 14, 2010 at 7:35:43 AM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:23 AM
Page generation time: 3.3586
