51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Manipulating Bar Joists
Wed, Feb 14, 2007 at 9:15:21 AM | Manipulating Bar Joists
CMcDowell
I am trying to use a bar joist, but rather than it running horizontal, I need it to run on an angle with the roof slope. I cannot seem to be able to get the right combination in the element properties structural analysis section to be able to angle it. Can someone tell me what needs to happen for me to do this?
Fri, Feb 16, 2007 at 12:32:07 PM | Manipulating Bar Joists
You can adjust the bearing heights of the bar joist by using the end level offset in the properties tag.
Sloping Bar Joists?
Thu, May 7, 2009 at 9:41:08 AM
Adding roof bar joists on different hight brg. ends..
Fri, Oct 9, 2009 at 12:02:50 PM
Revit 8.1 LH Series Bar Joist Insertion Problem
Fri, Dec 12, 2008 at 12:58:40 PM
Bar joist web
Tue, Jan 27, 2009 at 8:09:32 AM
rendering joists
Mon, Jun 27, 2005 at 2:07:04 PM
Page generation time: 0.4320
