44 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Revit Building + HVAC/Plumbing
Tue, Feb 13, 2007 at 3:19:46 PM | Revit Building + HVAC/Plumbing
Jhui
I know that Revit Systems, or I think I know that, is the one where you can do all the mechanical ductwork and plumbing lines.  Revit Building doesn't have those functions/components.  Is there a way to be able to lay out some plumbing lines in Revit Building or maybe some mechanical ductwork?
This could probably be done by massing some ductwork but that's sort of a roundabout way.  And I think I might understand that there are mechanical addons or plumbing addons - or is that referring to Revit Systems.
So many questions, so little time!
Tue, Feb 13, 2007 at 5:25:54 PM | Revit Building + HVAC/Plumbing
framerman
4 Stars: 13 Votes
well, I'm not positive, but check out Revit Systems on the Autodesk site and see if they allow a 30 day download trial of that software. you might be able to play around in there a little and see what you could use. I think there might be some families related to MEP's
Wed, Feb 14, 2007 at 11:18:43 AM | Revit Building + HVAC/Plumbing
Jhui
That's the thing, I don't think we're looking to purchase those other 'add-ons'.  We'd like to utilize Revit Building as best we can.
Tue, Mar 13, 2007 at 12:28:57 AM | Revit Building + HVAC/Plumbing
Enginator
5 Stars: 2 Votes
I'm thinking you can set something up with families of sweeps and such - and a library of elbows, unions, valves, etc.  Then piece them together in a project.  Doesn't seem hard at all.  The hard part would be making the parts and pieces to start off with.  If you can put together a library of parts for less than the cost of the Revit Systems add-on, then you're doing pretty good.
2014 HVAC and Plumbing shows on ribbon but no Electrical - All are checked
Mon, Mar 7, 2016 at 3:55:03 PM
Visibility
Mon, Apr 13, 2009 at 12:42:15 PM
Plumbing systems keep blowing up
Mon, Jul 13, 2009 at 1:04:59 PM
Revit Plumbing question for a 14 story building
Wed, Jul 24, 2013 at 12:14:57 PM
Revit MEP HVAC Lag?
Wed, Jul 4, 2012 at 10:58:47 AM
Page generation time: 1.7306
