44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing roof colour / material
Mon, Feb 12, 2007 at 11:33:06 PM | Changing roof colour / material
chehoun
Hi all,
I'm fairly new to Revit.  I've created a roof but cannot for the life of me get it to render the material that I've chosen.  The roof I've used is the generic roof - 125mm.  When I try to change element properties I need to go into "Construction" then "Structure" and change the material of a layer called Structure [1].  No matter what I change this to, it only renders one way - grey with some messy hatch.
I'm at my wits end!  Would welcome any assistance...
Thanks,
Nathan
Mon, Feb 12, 2007 at 11:54:59 PM | Changing roof colour / material
TomDorner
4.5 Stars: 25 Votes
You need to set the Revit material to an Accurender material.
I have kind of explained this in the attached document I wrote a while back on rendering and materials.
At home on the MAC now so don't have Revit fired up to get you a screen shot. [oh where is Revit for OSX!]
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Feb 14, 2007 at 5:55:59 AM | Changing roof colour / material
chehoun
Thanks for taking the time to reply - sincerely appreciate it...still I don't quite follow.
I've created a new material by duplicating and renaming it.  I've then assigned it an image map and saved it as user texture (somewhere) on my hard drive.  This doesn't seem to make any difference.
I understand that the 'shade' parameter in the materials library only works for shaded, not rendered, views.  Still, what HAS worked for the walls, gutter and fascia (changing their render material etc.) has NOT worked for the roof.
Still struggling here!
Wed, Feb 14, 2007 at 6:18:20 AM | Changing roof colour / material
chehoun
Hey I worked it out!!!
The roof was composed of three elements.  I was changing the material of the inner element, unaware that the two outer 'core boundaries' would prevent me from seeing it.  I simply added another element to the outer surface of the roof, called it 'roof material' and applied my render!
Works a treat!!  Shame it took this dummy so long to figure it out!!!
Changing the Colour of a Material
Fri, Nov 16, 2012 at 3:21:06 PM
Problems Changing Colours Of Doors!
Wed, Jul 1, 2009 at 3:24:18 PM
change colour/material of a beam
Sat, Dec 10, 2011 at 12:06:55 AM
Changing render colour of aluminium cladding
Thu, Mar 22, 2012 at 12:40:00 PM
Colour/Material change in project?
Thu, May 24, 2007 at 2:21:03 AM
Page generation time: 1.0495
