77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Why won't my material show up in my renderings sometimes?
Mon, Feb 12, 2007 at 1:08:35 PM | Why won't my material show up in my renderings sometimes?
c12rob
I have created a resteraunt with a lot of wood trim and posts. It looks how I want in every view besides the renderings because one certain material that many objects have in common will not show the correct color or material. I have taken Birch Wood and changed it to suit my needs of color and texture, and that is the only one i am having a problem with. It is not an AccuRender, it is a basic material. Have any of you had this problem, if so please help.
Cory
Tue, Feb 13, 2007 at 12:12:19 PM | Why won't my material show up in my renderings sometimes?
rkitect
rkitect Avatar
4 Stars: 29 Votes
Cory,
Is this a material that you added to the library yourself?  Have you moved the material library or render the project on a different computer?  If you'll notice under Settings >> Options >> Rendering all of the available material libraries are defined there.  If that material is not found at any of those locations it will not render properly come rendering time.
When I had this problem on a project before, the only way I could get it to render properly was to recreate the material in the material library.  Let us know if you find another solution.
material in renderings
Wed, Dec 12, 2012 at 2:14:22 PM
Renderings won't print
Wed, Mar 28, 2007 at 9:18:21 AM
Railing material won't show up
Wed, Jan 13, 2010 at 12:20:34 PM
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Hatch Pattern in GYP ceiling won't show
Thu, Mar 12, 2009 at 10:00:42 AM
14
Page generation time: 1.9988
