55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Make lines of walls dashed?
Thu, Feb 8, 2007 at 1:39:17 PM | Make lines of walls dashed?
MYoung
MYoung Avatar
Hello,
 Is there a way I can make a type of wall that displays as having a dashed line without forcing it using the linework tool.  I am modeling an existing wall which will be demolished, and I want that type of wall to typically display with dashed lines.
 Thanks
Thu, Feb 8, 2007 at 1:50:12 PM | Make lines of walls dashed?
MYoung
MYoung Avatar
Nevermind I figured out the whole phase thing; I never used it before.
Mon, May 3, 2010 at 3:38:49 PM | Make lines of walls dashed?
meaghank
I have the same question....I want to make some walls in my plan show dashed.  They're intended to be future TI build-out.  Do I have to use phasing for this?  I'm a very new Revit user and phasing seems to be a pretty cumbersome topic to tackle jsut to get some dashed lines.  Is this my only option?  Is there a simpler way?  If so, can anyone simplify phases for me?
Thanks
Tue, May 4, 2010 at 10:03:23 AM | Make lines of walls dashed?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
@Meaghank... search HELP for "Design Options".
 "If you tell the truth, you don't have to remember anything"
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
Underlay as dashed lines 2012
Sun, Nov 24, 2013 at 9:26:02 PM
Disappearing dashed lines?
Tue, Feb 21, 2017 at 2:16:48 PM
walls below floor are not dashed
Mon, Apr 27, 2009 at 4:38:31 PM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Page generation time: 1.4680
