Forums >> Revit Structure >> Technical Support >> Family tutorials
5 Posts No Rating |
hello...I downloaded a great tutorial on creating revit families from the Autodesk website. I got the link from one of Mr Spot's (thank you!) postings (which I can't find again). I'm about halfway through the 70 pages when it asks for a file under Training Files\Imperial\Families\i_Wood Floor Truss_1.rfa. I've looked all over (my computer, Autodesk website) and I can't find this file, or this folder. I'm using Revit Structure 4. The tutorial title page says Autodesk Revit Building 8.1 Imperial Tutorial, dated July 2005. It is one chapter, called Parametric Component Design Techniques. Does anyone know where I might find the files that go with this tutorial?
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
In return I'm asking you to post a link to Mr. Spots post with the link to this tutorial ![Smile](/images/smiles/smile.gif) Of course, this may not work if you're not using 9.1 ![Sad](/images/smiles/sadley.gif)
5 Posts No Rating |
Thanks, rkitect. I can't find Mr Spot's post, but I found the tutorial on Autodesk's website: http://images.autodesk.com/adsk/files/Autodesk_Revit_Building_8.1_Tutorials_Imperial.pdf (for Revit Bldg 8.1) http://revit.downloads.autodesk.com/download/9_1/TutorialsBuildingImpENU.pdf (for Revit Bldg 9.1) These tutorials are more comprehensive, but include the chapter on Parametric Component Design Techniques. Now, as for the file...thank you very much! But, the tutorial continues to ask for various files from that same folder: Training Files\Imperial\Families. I think I need that folder (and maybe others as well). I'm probably not the only one either. Does it come with Revit Building? If so, how can Revit Structure users get it? thx
![4 Stars: 13 Votes](/images/stars_4.gif) |
go to help>documents on the web and see if it takes you to the correct revit download section. I think you have to find a .cab file, or cabinet file
Edited on: Wed, Feb 7, 2007 at 7:07:53 PM
5 Posts No Rating |
Thank you Framerman...I downloaded the .cab files from Autodesk's Revit Structure download page, and also the.cab files from the Revit Building page and did not see those files in any of those! I couldn't find them on the page that has the tutorial downloads either. They must be somewhere?!?! Is there another section of the Autodesk website I'm not finding?
Email me we'll work something out to get you those files. rkitecsure[at)gmail.com
5 Posts No Rating |
Still in search of these files...did you get my email rkitect? I sent email via Autodesk's support site asking where they can be found as well.
I did receive your email, unfortunately a project deadline has been bugging me ![Sad](/images/smiles/sadley.gif) I'll try and get you set up before the end of the day!
5 Posts No Rating |
ah, deadlines...I understand. No worries...good luck with your deadline.
Sorry to take so long getting back to you. Check your email and let me know if you still need the training files.
