Forums >> Revit Systems >> Technical Support >> Crop Region Shapes
Hi, Can anyone tell me if you can change the shape, other than a rectangle or sqaure, of a crop region? For all those ex-AutoCAD users, a bit like the polyline view port feature. Some of the guys use white filled regions to block out unwanted sections but I feel this is asking for trouble. Thanks
Only rectangular crop regions available. This has been a wish list item for many years. White filled regions are the work around.
Tom www.reviteer.com http://twitter.com/Reviteer |
41 Posts No Rating |
Hi Guys, these comments were posted 5 years ago - anyone know if subsequent versions have included this feature, and if so how to utilise it? thanks in advance...
27 Posts No Rating |
I'm using Revit Arch 2012 and have the same issue. Is the masking region still the way to go?
Eric Sahnow
Project Lead/Designer |
I rarely use masking regions. I prefer to use the linework tool and the edit cut profile tool.
Can you please expand on this technique? One downfall I always hate about the masking region is that it doesn't cover up annotations, dimensions, grid lines, etc.
Eric Sahnow
Why would you want to cover up an annotation? If you don't want to see it, don't place it.
Bothcut profile an linework tool are very well documented with visual examples in your HELP.
crop region changes when placed on sheet |
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines |
Tue, Oct 19, 2010 at 4:00:29 PM
crop region - elevations |
Fri, Oct 23, 2009 at 12:43:33 PM
Room Tags Outside Crop Region |
Sun, Sep 10, 2006 at 8:05:26 PM
datum controls and crop region |
Fri, Oct 13, 2006 at 4:43:25 PM
Members: | 2115604 | Objects: | 23192 | Forum Posts: | 152303 | Job Listings: | 3 |
