45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sloped curved ramp...
Tue, Feb 6, 2007 at 5:34:10 PM | Sloped curved ramp...
Jh8man
I am trying to make a curved ramp that slopes up. I am working on a multi-level car park. Any advice?
Thanks,
James
Tue, Feb 6, 2007 at 6:01:33 PM | Sloped curved ramp...
Jh8man
Now I can make a curved ramp, but it will not slope...I'm stumped.
Wed, Feb 7, 2007 at 7:16:25 PM | Sloped curved ramp...
Jh8man
Alright, stop thinking about everyone! I figured it out!
Fri, Feb 9, 2007 at 8:52:23 AM | Sloped curved ramp...
arkitektmsh
3 Stars: 1 Votes
How did you do it?  I have an entry driveway to a large project that rises 12' and curves 90 degrees.  The drive should also have a counter-slope of 1/4" per foot for drainage.  I have tried using the massing functions and feel i am getting close,   but if anyone has had a similar issue that would be great.
Fri, Feb 9, 2007 at 9:41:45 AM | Sloped curved ramp...
Jh8man
I used the ramp tool combined with the geometry I learned eons ago in high school and was able to get the right slope with the curve. Then I realized that I couldn't attach walls to ramps, nor will ramps host things so I redesigned and took out the curve. I have not tried massing yet, but if you need a counter slope that might be the way to go. The ramp tool seems quite complicated, but with some persistance and the help files I managed to figure it out, which means any average intelligence person should be able to do it in 2/3 the time it took me.
Hope that helps...best of luck.
Fri, Feb 9, 2007 at 10:45:26 PM | Sloped curved ramp...
puzzle
4 Stars: 10 Votes
Try making the ramp from a floor and use the slope arrow to make it rise.
Macca
Sunshine Coast
QLD Australia
Mon, Mar 19, 2007 at 8:04:50 PM | Sloped curved ramp...
Irish
A sloping floor won't work because you can't define the slope to follow the curve, the slope arrow works only in a straight line. Even if you only define the grade using a slope arrow, you will find that one end of the won't be co-planar with the level you are connecting to. (refer attached images)
These are from current project, and this is bugging me. Is massing the best option???
Dale
Melbourne, Australia
Dale
Melbourne
VIC, Australia
Mon, Mar 19, 2007 at 10:09:47 PM | Sloped curved ramp...
psymon
psymon Avatar
3.5 Stars: 6 Votes
Create the flat section as a floor with a fall arrow. You need to create the curve separately as a ramp:
Draw a 2d line drawing to work out how long you need the ramp to be to achieve the required fall. ie: for a 1:5 ramp and you need to drop 1 meter, the length should be 5m.
Curved ramps have different grades on the inner and outer curve.The outside curve will be a shallower gradient.
The length you have calculated should be the length of the inner curve, the maximium gradient.
Use the ramp tool to draw a ramp with a 5m inside curve and define the base level and the top level.
That's it. If the material of the floor and the ramp are the same you can join them.
HTH - post if you need more advice, they can be tricky
Mon, Mar 19, 2007 at 10:17:59 PM | psymon
Irish
Quoting psymon from 2007-03-19 22:09:46
Thank you for that, I will try it. To the OP, this should work for you too???
Dale
Melbourne
VIC, Australia
Thu, Mar 22, 2007 at 5:52:59 PM | Sloped curved ramp...
Irish
OK, so i have manged to get this to work - however - when i try to select the sloping floor to connect to the curved ramp, the ramp isn't selectable geometry...???
Dale
Melbourne
VIC, Australia
Thu, Mar 22, 2007 at 5:59:14 PM | Sloped curved ramp...
arkitektmsh
3 Stars: 1 Votes
I might try to use the massing tool and then apply a roof by-face that replicated the floor type i need.  That way i can attach walls to the element.  I think this is the quickest way to get a coplex shape and i have had experience doing this.  I give the referenced option above a try as well.  Thanks
Wed, Jul 3, 2013 at 7:44:01 AM | Sloped curved ramp...
abdulameercp
Try to create ramp using run tool.
Hope it will work..
Sat, Oct 12, 2013 at 8:42:31 PM | Sloped curved ramp...
#13
ArchStudentWIT
3 Stars: 2 Votes
Try this link out, very, very helpful.
http://www.youtube.com/watch?v=5GaIarzxYPQ&feature=youtu.be
Sloped railing on sloped floor/ramp
Tue, Dec 9, 2008 at 9:25:01 PM
Spiral wall along ramp
Fri, Jul 11, 2008 at 2:43:00 PM
Curved Sloped Ramp walls
Sun, Oct 13, 2013 at 8:56:44 AM
How do you host a railing to a sloped floor when the floor is not "typical"?
Fri, Oct 16, 2015 at 9:31:11 PM
A ramp!
Thu, Jan 21, 2016 at 11:37:46 AM
Page generation time: 0.4684
