100 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit equivalent of the AutoCAD command "m2p"?
Tue, Feb 6, 2007 at 10:35:12 AM | Revit equivalent of the AutoCAD command "m2p"?
eyerina
Is there a Revit equivalent of the AutoCAD command "m2p"?  It places your cursor (for modifying an object, for pulling a dimension string, etc.) at the midpoint of any two points you select.
I was hoping I don't need to draw a drafting line.
Thanks in advance....
- eye
Tue, Feb 6, 2007 at 4:19:47 PM | Revit equivalent of the AutoCAD command "m2p"?
puzzle
4 Stars: 10 Votes
Revit does not have this particular command but it does have snaps similar to Autocad. Go to Settings<Snaps and it will show you all your options. You can change the Snaps shortcuts in the shortcuts file located in the program file.
Macca
Sunshine Coast
QLD Australia
Finding the Middle Point
Tue, Apr 8, 2014 at 9:19:11 AM
2013 - Elevation Questions - "Plan Region Equivalent" and "Underlay Equivalent"
Wed, Apr 30, 2014 at 12:20:55 PM
Why can't I make an "accelerator" so that space bar repeats last command?
Wed, Jan 9, 2008 at 12:35:49 PM
"stretch" command?????
Wed, Apr 5, 2017 at 3:38:58 PM
"Squiggled lines" in Revit
Tue, Jul 14, 2009 at 11:42:43 AM
Page generation time: 2.6140
