Forums >> Revit Building >> Technical Support >> RENDER RENDER RENDER
I'm just starting to render a small project we want to submit to an awards comp. I was wondering if anyone could help to point me in the right direction with links to forums, web sites or anything related to getting really nice renderings from Revit. I've looked around AUGI and RevitCity, but would like a little inside information on where the people in the know go. Thanks in advance for all the help!
you can try these to sites, they may be of help. they have lots on info and materials that relate to Revit's Rendering engine. http://www.ACCUSTUDIO.COM http://www.accurender.com/ HTH
If I may give a bit of advise to a new renderer, I would say that the best renderings come after many drafts. I render my scenes at 75 dpi dozens of times before rendering at a 300 dpi level. This gives you plenty of opportunities to catch all of those little details that set your renderings apart. Nothing is worse than waiting a hour or 2 just to find some mistake that requires a complete rerendering. Take your time. Also, use a real sky .jpg as a background instead of trying to get Revit to produce a believable sky. Good luck, and post your rendering when your done.
----------------------------------- ArchWestCY |
Render goes ok but when i change angle - the render is black |
Tue, Oct 20, 2015 at 4:38:12 AM
Revit render or 3ds max design render? |
Sun, Jan 4, 2015 at 10:19:30 AM
RENDER NOT HAPPENING... |
Tue, Sep 20, 2005 at 5:00:46 AM
render masterplan |
Sun, Jul 31, 2011 at 1:14:54 AM
New Render Appearance |
Tue, Jul 6, 2010 at 9:45:23 AM
Members: | 2106029 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
