64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> LIGHTS LIGHTS LIGHTS
Thu, Feb 1, 2007 at 1:53:09 PM | LIGHTS LIGHTS LIGHTS
jessephillips
3 Stars: 1 Votes
So, here's the deal.  <br /> I've made a light fixture from the light fixture family (non wall based).  I've applied translucent glass to the fixture and some aluminum accents.  <br /> I've placed it into my project and would like to turn them on.   How would I go about doing this?  I know this seems like a really in depth question...but I would like to know the best way to start turning on lights and rendering the perspective view.  <br /> Thanks in advance for all of you help!
Thu, Feb 1, 2007 at 6:13:52 PM | LIGHTS LIGHTS LIGHTS
archdan
3.5 Stars: 2 Votes
Typically by default lights are turned on when you import them into a project.  If they are not on, go to you rendering tab and select lighting, here you will find a list of every light in your project itemized by its item number. You can check and uncheck lights to turn them on or off as well as adjust the "dimmer".  An easier way to control lighting for interior or exterior perspectives is to create light groups (Rendering tab> Light groups). Here you can group lights to turn on or off and dim as a group.  This also will help to clarify which lights you are turning on and off.
Edited on: Thu, Feb 1, 2007 at 6:14:29 PM
Ceiling Lights don't self-illuminate
Mon, Oct 17, 2011 at 10:21:45 AM
Lights not acknowledged?
Thu, Jun 23, 2011 at 7:03:42 AM
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:37 AM
artificial lights not rendering
Tue, May 7, 2013 at 6:52:57 AM
exporing revit 09 to 3ds max with lights???
Tue, Jun 2, 2009 at 5:53:28 AM
Page generation time: 1.1260
