32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Yes/No Parameter Type - Toggling display of geometry
3 Posts No Rating |
I'm trying to create a family that allows for certain geometry display to be toggled via the Yes/No parameter. How do you assign objects to the Yes/No parameter type?
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Don, Set the Visible parameter of the object to the yes/no variable (by clicking the '=' button to the right of the visible parameter). This will make the object visible if the yes/no parameter is checked, and not visible if it is not checked. Check out this family for a fairly complex example: http://www.revitcity.com/downloads.php?action=view&object_id=3308 HTH
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
3 Posts No Rating |
thanks!
Using instance parameter in type parameter formulae |
Mon, Aug 12, 2013 at 8:22:38 AM
excluding a type in the family type parameter |
Thu, Mar 20, 2008 at 3:38:32 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ] |
Tue, Aug 27, 2013 at 3:53:53 AM
29
Including different formula parameter for each type? |
Wed, Sep 5, 2012 at 1:18:28 PM
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
Members: | 2026006 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
