Forums >> Revit Building >> Technical Support >> Drapery family
6 Posts No Rating |
Has anybody tried to assign a material to the drapery (curtains) family. This family is an Autocad import from what I can gather, try as I might I cannot get a material to stick to it. Has anybody managed this or am I missing something.?
try using the Paint Bucket and paint the material on HTH
6 Posts No Rating |
Thanks for the suggestion but it didn't work. Seems like I'll have to start fresh ans model the family for myself...L
The AutoCAD file should work without building a new one in REVIT. You need to verify what AutoCAD layer has the polymesh on it and you can assign your material to that.
Nevermind, didn't follow the whole conversation. Ignore this post.
Edited on: Thu, Feb 1, 2007 at 12:55:24 PM
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
6 Posts No Rating |
Good call.. Ahhhh, tried attaching the material to the layer but still no luck. has anybody else had any luck?
Create a family that includes another family |
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family? |
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project |
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message |
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3 |
Mon, Jan 19, 2015 at 2:43:21 PM
Members: | 2104866 | Objects: | 23178 | Forum Posts: | 152306 | Job Listings: | 3 |
