91 Users Online (90 Members):
Forums >> Revit Systems >> Technical Support >> visability problems
2 Posts No Rating |
Hi guys, i'm having problems with an elevation view. I have a toilet sitting in front of a tile wall, and the tile pattern is showing through the toilet. Its the only element in the view that it is happening to. It only does it in the side elevation, but not the front or plan. I have the visability set correctly (I think so anyway) and the view is in hidden line not wireframe, but it still happens. Also, it only shows up when i do print preview, not in the active view. I have tried everything and can figure it out. Any help would be much apreciated Thanks
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
A few things. First I would try printing with the Raster not Vector and see if that works. If not look at the family and check the visibility settings for the elevation view and see if the 3d model is visible or just a 2d wire frame.
----------------------------------- BallewDesigns.com |
visability problems |
Tue, Jan 30, 2007 at 10:44:00 PM
Visability parameter for dimensions |
Tue, Jul 31, 2012 at 12:17:05 PM
Visability/ graphics |
Tue, Mar 25, 2008 at 1:40:47 PM
Visability Parameter is greyed out |
Sat, Jan 24, 2015 at 4:10:27 PM
Sloped Ceilings |
Thu, Jan 23, 2014 at 2:38:10 PM
Members: | 2017421 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
