48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Text width for dimensions...
Mon, Jan 29, 2007 at 3:41:10 PM | Text width for dimensions...
rayhorn13
We've got Revit Structure 4 and I'm trying to tweak my templates.  Our default text styles are all set up to use 0.8 text width but our dimensions are showing up as 1.0 text width.  I cannot find any place to make the change specifically in dimensions.  Is it supposed to match the regular text style?  I thought so, but it definitely does not.
Any help is appreciated.
Thanks in advance.
Jeff
Mon, Jan 29, 2007 at 4:15:21 PM | Text width for dimensions...
coreed
coreed Avatar
4 Stars: 16 Votes
try Setting => Annotations => Dimensions
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jan 29, 2007 at 9:10:18 PM | Text width for dimensions...
rayhorn13
Thanks, but there is no setting in there to change or specify text width - not that I can see.
Any other possibilities you can think of?
Jeff
Tue, Aug 7, 2007 at 7:41:23 AM | Text width for dimensions...
phildixon
1 Stars: 1 Votes
I'm having the same problem in Revit Structure 2008
Tue, Aug 7, 2007 at 7:55:43 AM | Text width for dimensions...
JHanby
3.5 Stars: 3 Votes
Try going under the drafting tab and write out a line of text (the text you want to change) You should be able to change the width that way (under properites) and then the change should show up in the dimension text.  HTH
Can you adjust the text width for dimensions?
Thu, Oct 27, 2005 at 5:20:01 PM
text width factor for dimensions
Thu, Apr 20, 2006 at 7:44:22 AM
Text Box Width Factor Masking Error
Wed, Mar 18, 2015 at 2:33:51 PM
Adding Text Below Dimensions
Sat, Mar 3, 2007 at 10:55:05 AM
11
Rotating the text in dimensions
Tue, Feb 17, 2009 at 12:18:17 PM
Page generation time: 0.4010
