23 Users Online (22 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Truss roof display
Sun, Jan 28, 2007 at 7:10:00 PM | Truss roof display
GEFC
I am working on a timber framed project, two levels. I have put structure in for both first floor and timber turss roof frame. When I went back to edit the sheets I noticed that the truss layout was also being displayed on the floor structure layout, which is 2500mm below. I have tried turning off layers ect. but what ever I have tried I can not get the roof truss display off the first floor structure layout. Can anybody help me?
Sun, Jan 28, 2007 at 8:53:13 PM | Truss roof display
Westview
2.5 Stars: 2 Votes
Try adjusting the view range on the lower floor so its below the upper floor.
Sun, Jan 28, 2007 at 10:06:33 PM | Truss roof display
coreed
coreed Avatar
4 Stars: 16 Votes
also in the View Properties check your Underlay setting
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jan 30, 2007 at 3:44:09 PM | Truss roof display
lorifilbec
I had a similar problem.  In my case, I created them on level one and changed their offset position to be at the proper height.  Apparently, they will still show up in level one plan.  Create another level or reference plane and change the base to it.
Can't see Truss under roof
Tue, Feb 16, 2010 at 4:29:05 PM
Hip roof Truss
Fri, Nov 10, 2006 at 10:18:49 AM
roof truss install
Tue, Feb 10, 2009 at 9:00:56 PM
12
Revit roof... truss vs. rafter
Wed, Dec 18, 2013 at 11:26:22 AM
Truss overhang help
Wed, May 23, 2012 at 8:32:23 AM
Page generation time: 0.8838
