33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wood Siding
Mon, Nov 29, 2004 at 11:23:53 AM | Wood Siding
RevitChild
I am using Revit 5.1 I need to use wood sidiing on a cabin. How can I put wood siding on my exterior walls?
Mon, Nov 29, 2004 at 4:11:15 PM | RE: Wood Siding
lisab1070
4 Stars: 1 Votes
I just got finished with a log cabin that needed the same type of material. I took the wood image into paint drew lines through it and then added it to the material library. You can get a wood image from the materials contained in Revit by going to Docs & Settings>All Users>Application Data> Autodesk>Revit>Rendering> WebLibrary. Be sure when you open one of these materials in Paint that you do a save as so you don't overwrite the original. Draw a few black line across it. Go into Revit and select Materials from the Settings drop down menu. Select any material on the left side and select duplicate, give it a different name. On the right hand side select the texture under Accurender. Right click on the right hand side of the material library and select new> default gray. Click on the maps tab and add the map that you created in Paint. You may have to select edit and increase the size of the map depending on how it renders. Some maps appear too small or too large and can be adjusted.
Mon, Nov 29, 2004 at 4:57:43 PM | RE: Wood Siding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you actually want to model the siding, you can create a compound wall and add the siding as a wall sweep that is built into the wall by making a siding profile...
Tue, Nov 30, 2004 at 1:45:31 PM | RE: Wood Siding
RevitChild
Well I have made a Proflie of log siding and added that to my walls. Is there a way to have the profile repeat itself up the wall so that I don't have to enter it in at every elevation that I want the profile to appear?
Tue, Nov 30, 2004 at 9:26:20 PM | RE: Wood Siding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes, What i meant is: Select the wall you wish to have the siding on (remember all walls of this type will have the siding so if you only want it for this wall, duplicate the type and make a new wall type). Go to its properties, Edit/New, Turn on preview (bottom left of menu) and change to a section view. The sweeps and reveals should now be not greyed out so you can edit them. Select sweeps and start adding the siding profile, duplicating and changing the height until it is higher than the maximum height of the wall (you will receive warnings when placing walls as the sweeps that are beyond the wall height will not be created)... Let me know if this helps or not?
Tue, Dec 14, 2004 at 6:56:55 PM | RE: Wood Siding
RevitChild
thanks for the help, I have added the profiles to the sides of the walls, I did get some error warnings because there were a few of the profiles the were created above the height of the wall. I have found that these profiles slow down the drawings quite a bit. it works great though
Sat, Mar 17, 2007 at 1:18:07 PM | Wood Siding
adanedhel
4 Stars: 3 Votes
Ok I know this topic has been written long time ago but i need a wood aiding and couldn't find anything that works for me. I use R. 8.1 and I can't find compound wall. Maybe its the type of the wall that's name is CW... so... when i pick this type i can't find sweeps and reveals that should be grayed out. I understand everything that you wrote but just can't find it. plz help me with this. thx
Sat, Mar 17, 2007 at 1:39:15 PM | Wood Siding
adanedhel
4 Stars: 3 Votes
got it!!!!!   SmileSmileSmile  sorry for bothering.
Thu, Mar 30, 2017 at 2:56:35 AM | Wood Siding
scottrhill
Why is this not a feature all these years later? You guys were complaining about this when I was in middle school and Im fininshing a BS in Arch now!
Thu, Mar 30, 2017 at 6:45:23 AM | Wood Siding
scotthill,  What are you really saying?  The answer from 2004 still stands.
Fri, Nov 22, 2019 at 9:45:08 AM | Mr Spot
#11
hanbyjm
Quoting Mr Spot from 2004-11-30 21:26:20
"Yes, What i meant is: Select the wall you wish to have the siding on (remember all walls of this type will have the siding so if you only want it for this wall, duplicate the type and make a new wall type). Go to its properties, Edit/New, Turn on preview (bottom left of menu) and change to a section view. The sweeps and reveals should now be not greyed out so you can edit them. Select sweeps and start adding the siding profile, duplicating and changing the height until it is higher than the maximum height of the wall (you will receive warnings when placing walls as the sweeps that are beyond the wall height will not be created)... Let me know if this helps or not?"
So if I have an 8' tall wall and want to add 4" lap siding, I have to add 24 wall sweeps?  Is there not a way to array the sweep or set a parameter to the sweep to repeat the sweep?
Fri, Nov 22, 2019 at 3:17:58 PM | Wood Siding
#12
My post 10 years ago may help:
https://www.revitcity.com/forums.php?action=viewthread&thread_id=17944
rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:49:00 AM
revit 2015-exterior elevations horizontal lines of wood siding
Sun, Dec 6, 2015 at 10:01:16 PM
Wood siding
Wed, May 1, 2013 at 12:13:58 PM
Siding Sweep Return
Sun, Oct 30, 2011 at 5:57:53 AM
Walls with siding
Tue, Feb 28, 2006 at 5:21:50 PM
Page generation time: 0.2843
