49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> ACCURENDER
Fri, Jan 26, 2007 at 4:43:09 PM | ACCURENDER
vector23
vector23 Avatar
2 Stars: 16 Votes
hi everyone!
i talked to some guys at accurender..
nobody there told me anything like this
before but he said there would be no
point putting accurender 4 in revit because
it's still the same rendering engine except
the interface controls are changed but revit
has already changed the interface for revit..
what was good news for me was that he said
we can use all the new accurender 4 materials
with revit now.. plus he said there are other
places to get compatable materials..
i know accurender is old but i've seen so
many renderings with mental ray and i'm
not sure i want to change.. mental ray is
real good with reflection bounces but i don't
see the razor shape edges like i do with
accurender.. in fact if you turn all those
reflections off to zero in revit you get
really clear graphics.. i found the best
quality image is to render at 3 times
the size of your print layout..
if version 10 comes out with accurender
still there i won't mind a bit..
Mon, Feb 19, 2007 at 10:44:17 AM | ACCURENDER
rgaaia
just one question...what do you mean by "three times the size of the print layout?????"
Mon, Feb 19, 2007 at 3:16:52 PM | ACCURENDER
vector23
vector23 Avatar
2 Stars: 16 Votes
when you render you choose the size and you choose the scale..
those two things determine how big the picture will render..
(you never know how big the picture is rendering on screen
other than how long it takes to finish)
for example render any scene and save it as a bit map then open
it in paint..  you can print it 100% to whatever paper size
you are printing to or you can "fit to page".. say you are printing
to 11x17 paper and you select 100%.. if you rendered at a bigger
size than that it will print many pages.. but if you print "fit to page"
it will squeez it all on to the 11x17.. if you find the render size and
scale that exactly fits 11x17 and then render it 3 times you will get
the best "fit to page" print quality.. fitting 2 times larger than the paper
is a much improved print quality but 3 times is the best.. and more
does little or nothing..
my way of explaining it you may not fully understand but just
ask me more if you need..
Accurender ground cover
Wed, Feb 22, 2006 at 2:08:03 PM
Accurender
Fri, Dec 1, 2006 at 6:34:49 AM
Adding new materials to accurender library
Thu, Nov 19, 2009 at 5:44:18 AM
Accurender nXt for Revit. Alpha version available.
Wed, Apr 8, 2009 at 10:05:55 AM
Accurender file location
Sat, Nov 1, 2008 at 9:29:54 AM
Page generation time: 4.6300
