159 Users Online (158 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> autocad linked files and refresh
Fri, Jan 26, 2007 at 10:35:46 AM | autocad linked files and refresh
bballew
I always assumed revit would reload/refresh linked files on load up. Is this not true? I'm having some problems where even if i remove the linked file and re-add it, its not showing me the current 'linked file.' Even stuff that has changed in the linked file from a few days back. So is there a setting somewhere that controls refreshing linked files... or is there something I'm not doing to get these files to be current in revit?
Fri, Feb 15, 2008 at 1:39:51 PM | autocad linked files and refresh
Eric808
I am experiencing the same problem with linked AutoCAD files.  When I open the Revit file, it always says that the path of the linked file cannot be located etc., but the file is still located in the same path.  I tried unload/reload, but it still doesn't work.  Anyone have any ideas?
Thanks.
Fri, Jul 11, 2008 at 11:09:02 AM | autocad linked files and refresh
MADnes
Have you tried impoting your CAD file into a drafting view and then dropping it into a sheet as opposed to impoting it directly to the sheet. I believe that will fix your problem.
Gabriel Flores AAS/CDD, BS/CM
Fri, Jul 11, 2008 at 12:16:51 PM | autocad linked files and refresh
lunchtrayrider
3.5 Stars: 7 Votes
you want to make sure that you link it and not import it.  Make sure you get that check box checked in the import/link dialog box.
Tue, Apr 7, 2009 at 1:25:14 PM | autocad linked files and refresh
annies91484
i am trying to reload my linked file and it is not reloading the latest changes made to the .dwg
 any suggestions?
Tue, Apr 7, 2009 at 1:28:34 PM | autocad linked files and refresh
Are you sure you are pointing to the same file?
Did someone insert & link the file?
Tue, Apr 7, 2009 at 1:33:58 PM | autocad linked files and refresh
annies91484
i am reloading from the same file, yes and originally when i imported the .dwg i picked to link it.  i am going to "manage linked files" to reload.  not working when i get to this point.
Tue, Apr 7, 2009 at 2:12:37 PM | autocad linked files and refresh
First - it always works... unless you have done something different and I will bet that the file is inserted ... it may be also linked... somewhere else.  Unload the link and see if it goes away in the view.
Managing linked autocad files
Thu, Dec 3, 2009 at 9:19:43 AM
3DStudio max 13 and linked Revit files
Thu, Oct 10, 2013 at 10:22:49 AM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:44 AM
Linked Files Revit 2009
Wed, Aug 31, 2011 at 3:27:12 PM
Overridden line types of AutoCAD linked files revert back to <By Category>
Fri, Jun 27, 2014 at 11:58:48 AM
Page generation time: 1.1927
