90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> customize text parameter
Thu, Jan 25, 2007 at 9:14:50 PM | customize text parameter
Zone
Does anyone know how to link the text parameter to the text file, for example the assembly code when you click it will open the menu, how can i create things like that because i need have several code in one type.*example like a beam i need to give a code to volume and length i just want to select from the list exactly like assembly code but this one under instant parameter*
Fri, Jan 26, 2007 at 10:12:33 AM | customize text parameter
TomDorner
4.5 Stars: 25 Votes
There are a couple of possibilites to explore:
1.  Schedule Keys provide the database function of a 'lookup' table.  The Revit help file has some more information on setting these up.
2.  If there is a constant value for a given item, then explore setting up a 'type catalog' to use with the family.  When you load a steel beam shape in Revit for example the grid that appears for you to choose a size from is the 'type catalog'.
In both cases you may have to set up a 'shared parameter' to hold the value you are after.
Tom
customize dimensions?
Mon, Sep 19, 2016 at 2:13:57 PM
Can a shared text parameter conconate other text parameters
Tue, Dec 29, 2009 at 12:58:29 PM
Text as a yes/no parameter in a Tag
Wed, Sep 29, 2010 at 11:02:07 AM
Editable Text on Sheet without shared Parameter (simple way)
Mon, Oct 27, 2014 at 3:38:11 PM
Link Text to dimension parameter
Tue, Oct 4, 2011 at 6:29:44 AM
Page generation time: 0.5339
