37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimension to center line of doorway
Thu, Jan 25, 2007 at 12:12:23 PM | Dimension to center line of doorway
MrBob
3 Stars: 2 Votes
How can I dimension to the center of a doorway?
Thu, Jan 25, 2007 at 1:07:54 PM | Dimension to center line of doorway
quiller
quiller Avatar
2.5 Stars: 3 Votes
Bob,
Most families have center lines. You should be able to dimension to the center of the door by clicking on the mid point of the door, either in plan, elevaton or section. If you cannot add a dimension then you will have to add a center line to the family............If you don't know how to do that, open up a door that came with the application and use it as a guide.
Fri, Jan 26, 2007 at 10:01:21 AM | Dimension to center line of doorway
Westview
2.5 Stars: 2 Votes
An additional note to dimensioning. You can also edit the witness line, from a solid line to a centerline, so the items referenced to the center of a wall, window or door will show as a centerline.
Dimension center line of foundation
Thu, Oct 4, 2007 at 7:40:43 AM
Hidden dimension segment
Mon, May 3, 2010 at 9:06:52 AM
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
Moving dimension value
Fri, Jul 17, 2009 at 12:07:34 PM
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:50 PM
15
Page generation time: 1.5201
