87 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> half course masonry hatch pattern
Thu, Jan 25, 2007 at 10:28:03 AM | half course masonry hatch pattern
nicolle
4 Stars: 1 Votes
is there a way to change the hatch pattern properties so that the masonry hatch patterns start a half a course up instead of right at the bottom of the wall?  i need my opening heights to match my masonry heights in elevation views.
Thu, Jan 25, 2007 at 10:33:23 AM | half course masonry hatch pattern
TomDorner
4.5 Stars: 25 Votes
Assuming you used a 'model' pattern for the brick, simply use the align tool to align the coursing so an elemnt.  You can also select on of the pattern lines and move it [rotate it too]
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Jan 25, 2007 at 10:46:26 AM | half course masonry hatch pattern
nicolle
4 Stars: 1 Votes
thanks for the quick reply.  i believe that the pattern is a 'model' pattern.  i'm not sure, though.  it is the pattern that is the default on the masonry.  i can't figure out how to "grab" the pattern lines in the elevation view.  if i go to edit the face of the wall the lines disappear until i finish or quit the sketch.  how do i grab the lines to move them?
Thu, Jan 25, 2007 at 12:17:56 PM | half course masonry hatch pattern
nicolle
4 Stars: 1 Votes
i used the align command and it worked.  thanks!
Aligning hatch pattern on elevations
Thu, Mar 6, 2008 at 9:12:00 AM
Model Hatch Pattern - Align
Mon, Mar 12, 2007 at 3:45:56 PM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:36 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:52 PM
Hatch pattern on a wall
Thu, Mar 29, 2012 at 9:00:22 AM
Page generation time: 1.1991
