Forums >> Community >> The Studio >> "re-use/re-locate" feature
admin
I think it would be really helpful if the people at Revit developed a re-use or re-locate function where you can specify a component to be relocated in a certain phase. For instance, an existing light that I want to move to another part of the building. This would help with scheduling which objects are new and which ones are re-used and don't need to be purchased...
Hiroshi Jacobs
The Catholic University of America |
15 Posts No Rating |
Lets consider an ellipse tool also
admin
6.0 has an ellipse tool...you ellipses are a drawing tool option in the new release, however you cannot draw elliptical walls with the tool. (unless you do an in place family)
Hiroshi Jacobs
Well, shut my mouth wide open. just got the demo version and hadn't really test driven it yet.I stand corrected
62 Posts No Rating |
In a recent discussion I had with a Revit techie regarding phasing, they confirmed there was no 'tool' to distinguish reused items in a renovation project. However, you can add a field in your schedules for comments and call out save and reuse at location xx-xx. They said it was something they have on their to do list but, naturally, declined to mention any time frames. Interestingly enough you can not place new door/window openings in a refinished existing wall, Revit shows the cut in the new finishes but not the existing wall.
2 Posts No Rating |
I agree. In my job, I am always renovating and need to relocate / reuse an item (door, sidelight, etc.) from a demo phase to a new construction phase.
Locate a Linked File in a project |
Wed, Sep 23, 2015 at 3:24:29 AM
trying to locate a door tag tutorial |
Wed, Jul 23, 2008 at 12:57:08 PM
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:48 PM
exploded views and sheet feature in revit family editor |
Mon, Mar 24, 2014 at 10:55:30 AM
Can't dimension floor layers |
Sun, Oct 28, 2012 at 6:05:22 AM
Members: | 2105164 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
