54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Casement Windows
Wed, Jan 24, 2007 at 11:40:52 AM | Casement Windows
RSquared
the standard Imperial Library is inserting Casement windows without the swing operating lines showing in the elevations
is this a simple setting i need to adjust? or must i reinvent the casment window
the awning windows do show the V representing operability
Wed, Jan 24, 2007 at 12:34:41 PM | Casement Windows
quiller
quiller Avatar
2.5 Stars: 3 Votes
If you open both families and look to see the differences between them you should bo able to fituge it out. I'm assuming the swing line are present in the family and don't show up in elevation after you bring the family in. Hunt around for a line, click on the line and see what type of line it is. compair it to the awning window. If the lines are not present in the family, then add then to the family, again use the awnign window as a guide.
Casement windows in all sizes, anyone?
Wed, Jan 9, 2008 at 11:06:13 AM
Casement Window Operation
Thu, Dec 22, 2016 at 4:46:31 PM
Adding mullions to a fixed or casement window
Mon, Feb 27, 2006 at 1:52:14 PM
casement triple arched window
Tue, May 27, 2008 at 12:52:16 PM
Andersen double hung windows
Sun, Jan 18, 2009 at 4:45:25 PM
Page generation time: 5.9200
