108 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Scheduling Components
Wed, Jan 24, 2007 at 10:34:22 AM | Scheduling Components
hmunoz
We have shutters set up as a separate family under the category of 'Generic Model: Shutter'.  We place them in elevation using the component tool so they operate separately then windows.  I would like to create a simple schedule that counts the number of different size shutters within the project. Is there a way to add a category to the initial schedule creation window? or another way to simply count placed components in a schedule?  Thanks.
Wed, Jan 24, 2007 at 12:45:26 PM | Scheduling Components
quiller
quiller Avatar
2.5 Stars: 3 Votes
If you open the shutter as if you were going to edit it and go Setting, Family Category and Parameters, and change/assign a category….say Casework (you pick it)and then re-save and re-load the shutter family into your project. Then create a new schedule that looks at the particular category you assigned. Start off by dragging in all the fields and after you can clear it up. You should see your shutters………
Thu, Jan 25, 2007 at 1:57:41 PM | Scheduling Components
derxaj
3.5 Stars: 3 Votes
Follow quillers directions, but the main issue is that there is no way to schedule generic models, so you have to assign the family type to one of the other types if you want it to be scheduable.  You can then isolate the shutters, from all of the other families in the new assigned family type, in the schedule by filtering with a parameter in the object.
Wed, Jan 9, 2008 at 11:24:53 AM | Scheduling Components
CADorangutan
Actually, generic models parameters can become output in a schedule.
The first thing you need is a text file (.txt) created for shared parameters (File > Shared Parameters. . . ).  This text file is the critical "LINK"  between the parameters you create in a family (a generic model in this sample) and those which you would like to tell your project file to share, or recognize.  At the moment it sounds as though your project file does not recognize or link the parameters you customized.
 Steps:
1.  Create text file as outlined above (creating parameter category, parameters. . . )
2.  Save text file to network (or where it is easily accessible for all users)
3.  Create New Family (ie: Shutter) & add parameter.  In parameter creation dialog, select "SHARED PARAMETERS" read the fine print (". . . and appear in schedules and tags"Winking
Cheers,
scheduling dissimilar components
Wed, Mar 9, 2005 at 9:07:39 PM
Scheduling Components within Families
Tue, Dec 2, 2008 at 10:55:14 AM
Scheduling Nested Families
Mon, Mar 9, 2020 at 2:46:26 PM
Scheduling Coordinate Points for Complex Geometry
Fri, Jan 21, 2011 at 10:46:23 AM
Components on Level are Grey
Wed, Apr 17, 2013 at 12:56:07 PM
Page generation time: 0.4029
