Forums >> Community >> Newbies >> Specialized Training??
2 Posts No Rating |
Yup, a newbie here! Been using AutoCAD (now 2007) to do 2D space plans/elevations for Residential Interior Designers. Now have Revit, would like to move into 3D. Have some experience with C4D, ArchiCAD. Here is the question. There is a ton of stuff in Revit I will not use (at least for now). My clients want to have 3D view of interior rooms, with accurate ceilings, windows, doors, fireplaces, etc, and SCALED 3D FURNITURE. I get measurements from them (not dealing with detailed architectural measurement. ie, wall space is 42" to edge of window, window is 36" wide). What is the best way to learn what I need - how to get windows and door in the right places not using center points, how to model and changes sizes of furniture, how to deal with soffits, niches, ceiling vaults etc. I am willing to buy books, pay for training, whatever. Most books have about 1 chapters worth that helps me, the rest just does not apply. If this is the wrong program to used, too bad for me, I am a work from home mommy and do not have unlimited budget, so gotta make it work! (Diapers are priority over software!) Thanks!
Hi and welcome to Revit, have you tried the tutorials in the help menu????? second idea talk to your reseller for some kind of help from his side???? these forums are very usefull so if you can narrow down your questions there are a lot of people that will help you from here
13 Posts No Rating |
hi! and welcome. also try posting your qustions in the tech. support forum. reading other peoples qustions the answers to them is a very good experiance for beginers. this way you can avoide getting in the same problems.
Hi, Here are some my advices: 1. Learn the basic from tutorial: draw wall, floor, roof, ceiling, place door, windows, light fittings 2. Get used to daily used functions and shortcut keys: copy, move, mirror, array, trim, split, offset, ZO, ZW, ZE, SD, HL, WF etc. tab is very useful too. 3. Learn to create revit family and/ or modify from ex. revit family and/ or in-place family 4. Learn assigning material to object; placing camera/ walkthru; assigning lighting, and exporting image/ movie. That should cover your basic needs. other functions, please learn from revit tutorial and/or post your questions here or AUGI and let the masters help to solve your problems..like I did. ^-^ Good luck
----------------------------------- Life is never easy but nor it should be complex. Just stay simple  |
2 Posts No Rating |
Thanks for the support everyone! I am going to jump into the tutorials, then get into more specific questions, needs! Wish me luck!
additional revit training |
Thu, Sep 19, 2013 at 3:40:04 PM
AutoCAD training |
Fri, May 6, 2016 at 5:16:24 AM
Revit Training Classes |
Wed, Jun 10, 2020 at 10:42:52 PM
CAD Training Online to Provide Revit Training for US DOE Solar Decathlon |
Mon, May 21, 2012 at 9:35:18 PM
Revit Training |
Wed, Jan 25, 2006 at 11:57:09 AM
Members: | 2119053 | Objects: | 23205 | Forum Posts: | 152311 | Job Listings: | 3 |
