69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> View Range
Thu, Nov 25, 2004 at 12:06:45 AM | View Range
gY
I want to see the roofs below my First Floor plan and an outline of the eaves overhang above. I've tried the plan region tool and set the view range, view depth offset to -1000 and the bottom clip offset to -900 and top clip above the wall plate. the Cut Plane is the Parent View's Level. But nothing happens. Does anyone have suggestions how to get the view I want.
Thu, Nov 25, 2004 at 6:07:01 PM | RE: View Range
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'd use the underlay tool and underlay the appropriate level which shows the roofs you want to see, then use the linework tool on the roof edges for the roof above and below then turn off the underlay and the lines will stay and still referenced to your roofs...
Thu, Nov 25, 2004 at 8:47:14 PM | RE: View Range
gY
Thanks, I found that using View Range from View Properties wirks OK for View Depth. Is there a clipping plane for 3D views
Fri, Nov 26, 2004 at 1:10:50 AM | RE: View Range
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
For perspectives, YES. For Planometric 3D, Yes using a scope box, which you have to enable in the view properties then drag to where you need.
Sun, Jan 31, 2010 at 12:34:13 AM | View Range
Rhamed
Hi all,
Is there any other tool except the overlay for this issue.
Mon, May 17, 2010 at 4:48:56 PM | View Range
433Elarqui
Hello
I have a project with windows above the door header. How can adjust the cut plane to show doors and windows above at same level.
Thank you
view range
Fri, Sep 7, 2007 at 2:28:05 AM
View Range
Tue, Aug 28, 2007 at 9:52:28 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:19 AM
low wall not displaying correctly with view range
Fri, Aug 3, 2012 at 4:35:38 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:06 AM
Page generation time: 1.4943
