Forums >> Revit Building >> Technical Support >> Cutting a Void in a Roof Is it Possible?
10 Posts No Rating |
Okay is it possible to do a void in a roof, I have tried a number of times and get an erro saying that the void needs a mass to cut, it will not cut the roof? What am I doing wrong. Thanks
Try using the "OPENING" feature. It has several options that should get you what you want.
Or if your doing a roof by footprint, just edit your roof and sketch the hole in it.
Thanks, but neither option did work, i have attached a jpg, of the sevtion as you can see the roof, 12" generaic, extends below the roof slab, that is the area i need to cut/hide with a void. thnaks
17 Posts No Rating |
I know your roof is not made of rafters, but under the roof element properties properties under the construction category is rafter cut, change this to "Two cut plumb" and adjust the facia depth to the depth the dimension of the lowest edge to the roof deck. I think this will solve your problem.
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:44 PM
window not cutting joined roof |
Mon, Mar 6, 2017 at 4:23:51 PM
Is there a way to exclude what a void cuts into? |
Wed, Oct 23, 2013 at 10:42:01 AM
Cutting wall end with in-place void - Revit 2018 |
Thu, Jul 6, 2017 at 5:08:31 PM
Cut a Void out of i.e. 2x12 Roof If your EXPOSED Rafter tails are 6,8 etc. |
Thu, Mar 6, 2008 at 9:16:46 AM
Members: | 2114643 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
