75 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door schedule/frame width
Mon, Jan 22, 2007 at 2:39:23 PM | Door schedule/frame width
jstrauss
Is it possible to set up a door schedule that references the host wall width so that the size of the frame can be determined? We can set up the HM frames so that they adjust to the width of the wall but there appears to be no way to have the either the wall type or the width of the wall scheduled. Thank you.
Thu, Sep 13, 2007 at 9:25:29 AM | Door schedule/frame width
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
This is exactly the question I came searching for an answer to...so I'm replying to bump it up. There are Frame Width fields to add, but the results are few and inconsistent. Even something that just reports the Family and Type of the wall that the door is in would work for me ()since our wall names have the stud width in the name) at this point since I am just trying to generate a quick schedule for shop drawing generation/review purposes. Anybody?
Thu, Sep 13, 2007 at 9:48:51 AM | Door schedule/frame width
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Further searching seems to indicate that this is not possible, but the posts were long enough that they would not have been RA08, maybe something has changed?
Wed, May 14, 2008 at 11:12:57 AM | Door schedule/frame width
mthurnauer
3 Stars: 2 Votes
I have made my holow metal door type so that ir properly wraps the wall when inserted, but when I try an add a paramter to the door type that would report the wall thickness or overall frame width I get a message that I am overcontraining the model.  Has anything changed in version 2009 that would make it possible to report the wall width to the door schedule?
Wed, Mar 3, 2010 at 12:04:47 PM | Door schedule/frame width
Luigiman
I am using 2010 and still can't seem to be able to do this....
Door width for double doors appearance in Schedule
Wed, Aug 5, 2009 at 10:49:53 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
door schedule
Tue, Oct 7, 2008 at 1:32:16 PM
Same Door Type, Different Frame Type
Thu, Jul 24, 2008 at 3:16:26 PM
Door Schedule
Fri, Jun 23, 2006 at 4:53:50 AM
Page generation time: 0.9957
